1 - 8 of 8 Posts
1988 560SEL sold:
Any idea what these wires are?
1. A-Pillar driver side, there is a wire about 18 or 20 gauge poking out in between headliner and pillar moulding.
2. Under passenger seat. About the diameter of 75-Ohm coax cable. Closeup provided also - the thin white wisp is cat hair.
#2 I presume it was the cable that connected original carphone with the antenna (there is a remnant of antenna mount on trunk lid), but #1 I have no idea what that wire is doing up there[?][?][?]
1988 300E '91 560SEL
That is where someone cut out the Cell phone. If you check the trunk you will find the other end of that coax most likely, if not there it will be near the top of the back windshield. The part over your sun visor was the mike for the speaker phone.
Depends on the day!
Yup..looks like old cell phone junk..Either remove it completely or cut it back to where it can't be found/seen anymore.
Jonathan
93 190E 2.6; 82 300 SD Turbo
Jessie - 5/1/2005 6:15 PM
I never knew that! I always suspected that lil thing to be a sensor for the cabin temp or something, never would have guessed a cell phone mic, i wonder if it worked well. Gotta give it to Mercedes, ahead of their time.
Your arrow on the head linner is where I have the old biggo square micro phone. It is still there now. So I thing your mistery wire gotta be the micro phone cut out.
I leave it there because I want all original as much as it can be. My car is still original except for the glove box I added.
1988 560SEL sold:
RNMB - 5/2/2005 3:55 AM
Could I see some pics? I'm curious[:p]
1 - 8 of 8 Posts
