There was a stain on my driveway yesterday. It was from my 2003 E320 wagon at the right rear wheel. It appears to be light petroleum with no odor. My guess would would be SLS fluid.
I check the SLS reservoir and the level seems fine. Not absolutely sure as driveway is sloped and fluid was maybe 3/8 - 1/2" below max mark on the front of the tank. I topped it off to the maximum line and will check again tonight when my kid return home from work.
I jacked up the car and removed the wheel. It appears fluid is dripping off the subframe mount and down the front lower control link. EVERYTHING else was dry. I see no fluid spray. It almost appears as if the subframe mount was fluid filled and sprang a leak!
All lines (brake & SLS) are dry and also the following: the accumulator, hydraulic ram, fluid control valve, top and bottom of subframe and the area above the subframe mount!
I measured the fender lips on both side and they were within 1/8" of 27 1/2''. Any guess/insight were this fluid is coming from?
