1985 500 sec euro
I have a 85 sec euro coupe and the roof will only retract but it will not vent. Was that from the factory or is it broken, can anybody help me. Thanks
too many
Do you mean tilt? It may not, I think the gen1 cars may have either not had any tilt, or it was optional.
1989 Mercedes Benz 560SEL
what about if your moonroof doesnt open at all? is it possible for them to be knocked off a track or something? when i press the button i can here a motor running so its not a fuse problem, and when u look at it from outside, it is angled slightly upward from the back. (enough to see light shine through)
2012 CL550 4MATIC Coupe
Markus is correct. According to the B&C manual, Gen I cars only slide open and closed. I do not believe it was ever an option.
It uses a completely different motor unit that has a different circuit in it for the stops.
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
The 'welcome to...' announcement / tutorial sticky on top has the info on how to search the forum archive.
'00 Mazda MPV, '98 Chrysler Cirrus
My '85 doesn't vent either, so +1 on not available.
83 500SEC, 84 300TD, 86 190E 5.0 M113, 87 300D, 01 CLK55, 02 C32, 02 C320T, 03 C320T4, 03 E55
80-85 sliding roof only (switch on console)
86-91 sliding-venting roof (switch on overhead light)
