91 600SEL
Well after trying everything in the book and rebuilding my whole front end, I finally found the reason for my 65mph/shake . It turned out to be comming from the rear not the front as it seemed and new outer lower control arm bushings did the trick!! just a little something for you guys to check if you have the problem!!
Moderator
3phase-4pole
oh man, why didnt I think of that
I will check it out, thanks
1993 S600 Lorinser
I have a shake in the steering wheel but at a lower speed and through to about 65mph. I was suspecting front end bushings but perhaps I should be looking at the rear now too. Thanks for the post!
