1987 420 SEL
This morning I pulled over to clean my rear window. When I went to move the gear shifter from 3 to P, it would not go past R. So I moved it back down to 2 and tried again this time it went straight thru with no problem.
Now this afternoon, it did the same thing. I did have my gear shifter bushings changed about 4 months ago. Is there anything that I should look at first? Any help is appreciated!!! Thanks.
Smoke Silver '87 560SEC, Black Pearl '87 560SEL
Does the shift linkage feel loose? No free play apparent? I'd guess that a shift linkage bushing fell out. Those things are HARD to get in and it may not have been installed completely and one fell out??
The only other thing I could think of that is easily checked is the linkage on the transmission to which the shift lever rod attaches. Loose bolt?
1987 420 SEL
Sounds possible. I'll have to get under there and examine this evening. The shifter still feels tight though.
