1985 190E 2.3 (Sold)
Remove the door panel and check the wiring. Sometimes the wires lose connection somehow. If all looks good....its most likely that you need a new window motor. Could possibly be the window switch, but I doubt it. You can test the motor to see if its good by directly hooking it up to the battery.
190E 2.3
The window switch of mine works on the left rear.
If it works on the left rear would it mean that it works on the right front, and that it would be the window motor ect... Thank You
P.S. the car is a 1986 190E 2.3
