1 - 11 of 11 Posts
10 Mercedes e350, 09 Mercedes GL450, 95 BMW 325IC, 89 Mercedes 260E, 84 Euro Mercedes 300D 4spd
in my 96 s320 driver side turn signals blinks very fast both front and rear
but left side blinks normal. did any one had the sam issue? how did you fix it?
thank you for any replays:bowdown:
Zotye Auto 1.5T T600 2016
It blinks fast to tell you one of the lights is not working. Put it on right turn and check the lights front and back.
Well here is the thing, all lights are working
But blinking fast like one of the bulbs are out
In that case it may be a high resistance on one of the bulb connections, clean the connectors.
Will do, let you know on Friday,
Thanks in advance,
2002 Black SL500, 2000 Azure blue SL500, 2005 Silver (A209) CLK500
Fast blinking indicates a bulb problem....could be a short....turn the driver's side turn signal on...is it blinking fast? Yes? Problem is the left side. If not, do the right side.
Step on the brakes with the turn signal on....try both sides.
Right side works normal, it just the driver side acting like one of the bulb is out but all bulbs are blinking two in the back and one in front,
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
LoL, That happen'd to me at 4 am in the Morning on my way to Work , i stop't the Car until i found what it was,stuff Work punctuallity the Car has to be perfect ,lol , it took me ages to figure out that the W140's have 2 rear Blinker Bulbs ,anyway i changed them and all was good again but 1 of mine was blown at the Rear ,if your's does still blink (2 ) at the Rear try either swap the left side to right side just to see if it is the Bulbs wich are defective (sometimes they are ) otherwise i thing it could be the Relay.
1 Bulb is Bigger and 1 is slightly smaller ,the one on the round edge .
Ciao :thumbsup:
'84 300DT, '97 S320
mers320: is your car RHD ? In your 1st post you said "driver side turn signals blinks very fast ... but left side blinks normal." In any case, this symptom is probably caused by what everyone has said. It happens on all kinds of brands of cars. Many years ago this happened on my '74 Plymouth Duster - one of my first electrical lessons.
On some cars, depending on just which filament is bad, e.g. the front left is good but the rear left is bad, the good front left and the dashboard left arrow will come on, but just steady with no blinking. Depends on just what kind of blinker mechanism you have.
Years and years ago, the blinker item contained a piece of metal that initially made contact with something else and all the correct lights would be on once the turn stalk closed a switch. Once the current was flowing, the metal heated up, and eventually would bend away from the contact, and the lights would go out. The metal would cool, make contact again, lights on again, etc. etc. Nothing electronic -- just mechanical. These would also wear out about every 2 years.
After re-reading this, it may seem I'm saying the blinker mechanism is at fault. Au contraire, a bad bulb (or unclean bulb, or unclean socket contacts) is definitely the cause -- I'm guessing that different blinker mechanisms could produce slightly different symptoms : fast blinking, on but no blinking, not on at all, etc.
Discussion Starter #11
thank you guys,
problem fixed it turns out to be a bad connection between front driver left light bulb,
cleaned it off and started to work as usual,
:bowdown:
1 - 11 of 11 Posts
