1 - 15 of 15 Posts
Login | Facebook
Sorry dont know how to individually post pics came out sweet tho!
Gene,
When you open the screen to post scroll down to the bottom and you will see manage attachments. Then just scroll to the place you have the pics stored and upload them. Not the post quick but use the go advanced.
2001 Mercedes Benz ML430 w163,2008 Mercedes Benz CLS550, RIP Mercedes Benz 1996 e320 w210
yea! re-upload cuz we cant see?!
really interested how it turned out.. :D
16 Silverado CC LT 4WD, 12 BMW K1600GTL, 11 Infiniti G37, 10 Infiniti G37x
Looks good.
Not that it would be something I'd do to my car as I like the single DIN, it but sure looks like pretty easy DIY.
BTW, that upper part of the console looks really bare when it only has those three switches. :eek: I guess I'm more used to it being full of them as mine has double the amount. :D
I want to do it on my car, too, but I got a question.
According to the 3rd picture (from the bottom up), do I need to turn on the AC when doing the work? Or only turn on the AC in summer time?
1997 Mercedes Benz E320
I realize the thread may be old, but I just found it it now, I'm planning on doing the same thing to my 97' E320. Can you give some steps on how you set it up so beautifully. Not only I but I'm pretty sure everyone that has a w210 would greatly appreciate it :)
zodiac91, I hope the additional info will be of help to you and others. I did a copy and paste of some info that I posted on another forum. Some of this may be a repeat of what you already read. (sorry) As for the steps involved in removing the single din cage and replacing it with a double din cage, there are already some good posts either at benzworld.org or mbworld.org explaining this step by step. Simply search the w210 forums for double din conversion.
I purchased the new double din bracket or cage (Part number 2106890916 - Reinforcement for 2000 - 2003 E320 - $30 plus shipping) and new burl wood double din bezel or console (Part number 21068023367400 - COVERING - $243.80 plus shipping) from Parts.com. The new bezel or console had to be ordered from MB Germany, and it comes with seven (7) button holes across the top. Since my old burl wood console only had three buttons across the top (including the emergency flasher button), I had to order four hole fillers or covers for the four extra holes in the new burl wood console (Part number 2026831310 - BLIND COVER - $5.29 each), also from Parts.com - Joe was quite helpful with researching and handling the order. (See photo with blank buttons.) The most difficult part of the conversion was removing the old cage or single din reinforcement bracket. I simply read the threads on how to do the conversion and followed the step by step directions of those who came before me. I owe all of them a big thank you for the great information and directions. With that said, once you get to the actual single din bracket, be patient and persistent, it will come out. If I had it to do over again, I would probably remove my glove box, as suggested in some of the threads. This might make it somewhat easier to remove the single din cage and install the new double din one.
I purchased the antenna adapter and wiring harness from Crutchfield. (However, I didn't really need to use the wiring harness since my radio/head unit came with the Euro harness. It was plug and play.) Yes, I did the wiring myself. The most difficulut part was wiring the backup camera. I had to tap into my rear backup light wire. I also tapped into my rear lamp wire which is the same as tapping into the headlight wire in order to have the radio dim when I turn on my headlights at night. I took a chance and purchased the radio (7" DVD Navigation Radio) direct from China from chinavasion.com. I bought their Gladiator unit and it is virtually a perfect fit. It works great and the sound is very good. I am quite happy with it. (cost under $300) Check out the site and you decide. I used ABS plastic to hide a 1/8" gap between the radio and the double din opening at the top and bottom. I bought the abs plastic from parts-express.com. As I said in my original post, check with parts.com for the double din burlwood bezel and cage/bracket. Better price and faster service than Netherlands guy.
My car is a 97 E320 that came with the factory radio unit. The amp was built into the radio. No external amp unless you have the Bose system. If so, I believe there are post that guide you through how to do the wiring.
A few more things that might be helpful to those of you doing the conversion, the wiring harness I purchased is the same one used for a VW. If you purchase it from Crutchfield, as I did, it will come with instructions. Just enter you vehicle make and model and search the Crutchfield site for radio wiring harness. One of the modifications you may need to make is to cut the body of your factory radio harness in half (separate the A and B connectors) in order to get the ISO harness (adaptor harness) to plug into the factory harness. Don't be alarmed, I did it and it was big deal. Just wanted you to know. Crutchfield explains this in their instructions. If the aftermarket radio you install requires you to tap into your car's speed sensor wire, I read somewhere that the 97 e320 has a speed sensor wire built into the factory wiring harness (I believe it is connector A, pin 1). This is what causes your radio to increase or decrease the volume automatically when you drive fast or slow to compensate for road noise. (My old Becker unit did this, which was actually an interesting feature.) Anyway, look at your factory harness and you will be able to identify the A and B connectors and the pin numbers for each wire. Lastly, the backup wire (hot or +) for my car is the gray with yellow strip wire and the rear lamp wire (hot or +) is the gray with black strip wire. Have someone put the car in reverse while pressing the brake pedal while you test for the backup hot wire using a 12 volt tester if necessary. Turn on your headlights and test for the rear lamp hot wire if necessary . I hope this all makes sense. It really is not as complicated as I am making it sound. Just trying to be helpful as so many others were for me.
1 - 15 of 15 Posts
