1 - 9 of 9 Posts
1997 E320, 1997 S320
musikmann, it is not the steering wheel. if you grab and move up and down the lever for turning signal/high beams or the cruise control, the whole plastic covering moves with the hand movement. the movement is about 1 inch up and down. the levers function perfectly fine. mine started doing over a year ago, but i didn't pay much attention to it since i didn't think would hurt anything. would like to know the fix for it though.
'01-E320 & 02-ST2
Here sticky...here sticky...
Just a tip/reminder for newer folks...most of the stuff you'll face with your car has been covered and can be found in the HELP/DIY stickies that appear at the top of the forum. Read through the entries when you have a chance, and remember to always look there first. Between the stickies and thoughtful use of the search functions you'll find a wealth of knowledge and an answer to about 90% of the stuff that comes up.
2007 Mercedes ML500 2000 Mercedes E320 1999 Mercedes E430 1996 Mercedes SL320
1 - 9 of 9 Posts
