1997 SL500
Drove my car the other day and all was good...Went home and installed a new dome light...After fixing that I started the car and all of my gauges and info center stopped working....Then the car wouldnt start after that...I charged the battery for a while and she fired right up....Shut it down and restarted...Dead...charged battery overnight and it fires right up...Now the weird thing the power locks, antenna, the cluster mentioned above, the power window door closing crack doesnt work...The roll bar that was not working anyways is half way up now...WTF:confused:Ideas???
· R129 HTT Founder Member
040 96' SL500, 368 08' E550 4Matic, 9147 13' Sprinter 2500
I would look at the fuses, battery condition and alternator in that order. Did you do any wiring with the dome light or just plug and play? Is it the same part number as the one you replaced?
Sent from AutoGuide.com Free App
1997 SL500
Discussion Starter · #5 ·
I had to resynch the power windows...2 blown fuses...Everything up and running again...Have a check engine light now...Looks like the battery needs replacing...After that I will check the charging system...
