I have finally went ahead and put 18 inch RIMz on my BENz.
Pictures of the car available at the link below.
http://myc230benz.shutterfly.com/pictures/36 - New RIMz :thumbsup:
Below is the problems I have with the car.
=== Stored Error Code(s) ===
Error Code: P1519 - RH Adjustable Camshaft Timing Solenoid (Logic Chain)
Possible Causes: Not Sure?
Error Code: P0400 - Exhaust Gas Recirculation (EGR) Malfunction
Possible Causes: EGR valve, Vacuum lines damaged/disconnected, EGR solenoid.
eBay EGR Valve: AIRTEX 4F1993 EGR Valve | eBay - $176.13
eBay EGR Valve: IMC 145 33038 001 EGR Valve | eBay - $311.60 + $10.00
=== Pending Error Code(s) ===
Error Code: P0105 - Manifold Absolute Pressure (MAP) Circuit Malfunction
Possible Causes: Vacuum hose damaged/disconnected, Bad MAP sensor, Bad TPS.
MAP Sensor - eBay Searched: 1997 C230 MAP Sensor | eBay
TPS Sensor - eBay Searched: 1997 C230 throttle position sensor | eBay
Error Code: P0422 - Main Catalyst Efficiency Below Threshold (Bank 1)
Possible Causes: Bad or non-functional catalyst, Engine operating out of optimal air:fuel ratio
Freeze Frame Information:
1. DTC for which Freeze Frame was Stored - P0105.
2. Fuel System 1 Status - Closed Loop.
3. Fuel System 2 Status - Not Supported.
4. Calculated LOAD Value - 17.65 %.
5. Engine Coolant Temp - 194.00 °F.
6. Short Term Fuel Trim - Bank 1 - -3.91 %.
7. Long Term Fuel Trim - Bank 1 - 3.91 %.
8. Intake Manifold Absolute Pressure - 19.25 Inhg.
9. Engine RPM - 1,675.00 Rpm.
10. Vehicle Speed Sensor - 36.04 Mph.
Monitor Information:
1. MIL - OFF.
2. Misfire Monitor - Complete.
3. Fuel System Monitor - Complete.
4. CCM Monitor - Complete.
5. Catalyst Monitor - Complete.
6. EVAP Monitor - Not Complete.
7. Secondary Air System Monitor - Complete.
8. O2 Sensor Monitor - Complete.
9. O2 Sensor Heater Monitor - Complete.
10. EGR Monitor - Complete.
Still looking for a "Front Bumper Assembly" and "Hood"
(I have purchased the 2 Fenders already.)
Thank You For Any Help!
