2000 ML320
I fished a quater out, but the ash tray still won't stay down In the lock position. Is there a quick fix for this? Oh the ashtray belongs to a 2000 ML 320.
Thanks In advance.
Mine did this once. I just removed it and messed with the mechanism a bit and it started working again. IIRC, the gear was misaligned and just had to be put back in place. You’ll have to remove the wood panel from the center console to get to it. Look here for details on how to do that (ignoring the part about repairing the window switches).:
http://rodneygrill.com/mclass/mlswitch/index.html
- RODNEY
2000 ML320
I wouldn't go that far to fix the ashtray. I too had that problem. You don't have to remove anything except for the cover that closes the ashtray itself. Just undo one side and then the next...and reattach it.
