Re: My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (....
Man, that is rough. The 3.2L six is Mercedes' equivalent of the '70s Mopar Slant Six -- thoroughly bombproof and basically indestructible despite almost any realistic degree of human neglect. I mean, the OHC V8s are a little finicky, but the 6s? <br> <br> One possible suspect for oil leaks is that your breathing/PCV system is out of whack -- e.g. the PCV is for some reason plugged up and isn't able to pull suction inside the block. I assume that you've stuck with OE parts and if that's so, I admit that I've never, ever heard of such a thing on a Merc, unless for some reason the system's simply hooked up incorrectly ... you may want to give a few minutes' study to those hoses.<br> <br> Which gasket, exactly, do you mean? There are at least four main gaskets at issue here: head, oil pan, rear main seal, and front main seal. Do you have any more specific info.?
