1984 380sl
1984 380sl. After stalling at one stop sign, it started and I drove to the next, about 200 ft., it stalled again. I restarted and drove to the next stop, and you guessed it, it stalled again, and did not re-start this time. It cranks just fine, tank is full of gas, and vehicle is in Park. I am thinking possible fuel pump problem, any suggestions?
Might be the fuel pump
It's a long shot, but you can try replacing the fuel filter.
My guess is that your fuel pump is gone.
I've got a factory service manual on CD for the R107 chassis at home.
I'll see what it says about how to check the fuel pump and email you later.
Sent you email
Check your email. I sent you a PDF file that might help you diagnos the fuel pump problem if that is it.
