Re: my 300D is very slow off the start - update
This is an update since my last post in June 2000. Since then, I bought a fixer-upper '87 300D (which I still have), a 1983 300D (which was totaled), and a 1984 300D to replace the wrecked one (wife's car). From what I've learned, the problem is VERY likely to be the ALDA adjsutment. My 'project' 87 is a rocket off the line. The 83 was so-so, but not bad. The 84 had the ALDA adjusted by the PO and it also gets off the line quickly.<br>
<br>
Now, my other 87 was so-so off the line, not nearly as snappy as the fixer-upper I got with the same engine. While doing the head replacement job (long story), I pulled the injection pump to have it calibrated. The shop said it was off from specs, a little low on fuel delivery - which was why the power was down. They got it set properly. I asked about the ALDA and they said the proper way to adjust it is internally on the I/P, but you can remove the 'tamper seal' on top of the ALDA and do it there. The car isn't yet reassembled so it hasn't been test driven since the I/P calibration.<br>
<br>
WARNING: I have heard that there is a slight (10-20%) chance that by adjusting the ALDA, it may break internally. It's not available separately. Just FYI. Anyway, the URL below shows a photo of the ALDA with the tamper cap removed with pliers. I did this on my sister's 87 300D (yeah, we like them W124 diesels!) I loosened the locknut and turned the setscrew 1 turn counterclockwise. It made a very noticeable difference in off-idle power! I actually need to adjust it a bit more, haven't had time though. Basically you adjust it until the power is good. If the car smokes, you went too far (too rich), back it off a little. I've been told that most require 1-1.5 turns CCW.<br>
<br>
Now, the PROPER way to fix this is to remove the I/P and take it to a Bosch shop for a bench recalibration (~$150-$200). But, if you're feeling lucky this trick may do the same thing for free. On a W123 it's simple, on a W124 you have to remove the intake manifold to access the ALDA - very annoying. Also, there is a little-known procedure in Mercedes dealers Workshop Information System that documents this, although they recommend a 1/4 turn, and that just isn't enough.<br>
<br>
Note: This applies if your car runs good otherwise, and has 'normal' power above ~2000rpm, when the turbo is producing boost. The ALDA adjustment basically is setting the fuel quantity minimum setting. If you have other problems, this won't cure them.<br>
<br>
<br>
Hope this helps some of you out there!
<br>
<br>
Dave M.<br>
Sacramento, CA<br>
1987 300D - 229kmi (recalibrated I/P, new head)<br>
1987 300D - 237kmi (project, needs new head)<br>
1984 300D - 207kmi (wife's car)<br>
1981 VW Dasher diesel - 170kmi (beater)<br>
<br>
1983 300D - 30xkmi (totaled)<br>
1983 240D - 204kmi (sold)<br>
1990 300E - 75kmi (sold)<br>
Plus four previous Dasher diesels and other misc...<br>
