My 1986 M117 duty cycle is same 48-50 idle and 2500RPM.
In H.D.s lambda tutorial he states "for years 86 & 87 M116/M117 mean value at idle should be 5-15% higher than the mean at 2500".
Can anyone tell me :
1)why for years 86 & 87 M116/M117 mean value at idle should be 5-15% higher than the mean at 2500.
BUT
2)why duty cycle should not differ more than +/- 10% for model years other than 86 & 87 M116/M117s
3)most important why am I getting same 48-50 duty cycle @ idle and 2500 on my car if idle should be 5-15% higher than @ 2500 RPM....is there something wrong??
4)Other than idle fluctuating 50RPM instead of a rock solid idle that H.D. says should be present if all OK my car runs great.
So......anyone help out with answers to 1, 2, 3 and 4.
Other than slight vacuum leak at throttle body shaft seal everything is OK ....only thing not replaced is EHA.
Help with 1-4 above pls.
Tx, Steve
BUT
Tx, Steve
