I doubt if its a bad battery or you would not get it started again. If its turning over OK...
I doubt if its a bad battery or you would not get it started again. If its turning over OK its probably something else. The first thing I would do is put a bottle or two of Chevron Techron in the gas tank. Run it a little and let it sit. If that dos'nt work you are going to have post more discriptions of your problem so we can cypher if its a fuel or ignition problem. When was your last fuel filter and distributer cap and rotor? Maintaince history is important. Wal-mart sells the Techron. Ive such good luck with it I would'nt recomend any thing else.
