1 - 20 of 21 Posts
Discussion Starter #2
Anyways so went shopping time to make my cab enjoyable :) I had the amps and sub already
1.JVC MP3 Player with rds, usb, ipod and 3 sets of rca so I can connect all my amps
2.12" Logic Sub Box
3.Pioneer 500w 6x9's
4.Kicker 4" co-axles (excuse the spelling)
5.Kicker 12" CompVT sub 400RMS @ 2 Ohm
6.4 Gauge Wiring Kit
7.Monoblock Amp 500RMS @ 2 Ohm
8.4 Channel Voltmeter Amp 75RMS per channel @4 Ohm
I was itching to do something so I started with the Sub Box, I removed the Kicker sub from its box and put it in the bigger box for deeper bass as I was using there compact box before.
Foam Tape was placed around the speaker and soldered the terminals with the speaker wire and sealed the hole were the box terminals
are with silicone from the inside so its completely sealed
End product...
I am gonna make a backboard and mount the 6x9's hopefully the mdf board I have is long enough for the shelf
My inspectors are making sure I do it correctly lol
I decided to make a custom backboard to house a set of 6x9's without cutting the metal
Its very possible and you dont need shallow mounting 6x9's either. Took me 4 hours to make but totally worth it !!!
Ok so I pulled the rear interior basically same setup as w126 and w124
Copied the original Backboard to a piece of chipboard
After 4 Hours its done !!!
Been busy the whole day lol
Did some sound deadening to the rear tray
Front Speakers new and old
Rear speakers new and old
To wire this car has truly been hard the backboard/6x9 has issues I need to cut some metal
Need to make mounting area in boot for amps
gonna wire the stereo and test :)
Ok so I am 75% done with the sound install
I removed an aftermarket nokia system and cleaned up the wiring
Radio is in
This radio has the following
*USB with ipod compatibility
*3 RCA Connections
*2.5v output for amps
*3 Band Pre Amp
*2 x Auxallary ports
*Bluetooth compatible going to get my bluetooth device soon :)
6x9 still need work, I need to cut some metal :(
Here is why I need to cut the metal about 10mm on the 1 side of the speaker it sticks out because of this
So this is what I am left with
This car was very similar to my 280se that I did but worse lol. cable install was intense to get neatly done
So what I need to do is :
*Install Blue tooth device
*Create mounting board for the amps in the boot similar to the 280se - a board in front of the fuel tank
The mount you made for your 6" by 9"s looks a lot like mine! Except the only difference is I put my amp right in the middle of them. :thumbsup:
Very nice :thumbsup:
I think yours is the first 201 I've seen with a trailer hitch.
Finishing of the sound install
Took me the whole day but its finally done !!!
Since I had no where to mount the amps I made my own design
The mounts
Finished covering it
Mounted and this works well
Cut metal out for 6x9's to fit 100%
Set my radio color to match the switches
Ok so the grille was not sitting flush at all and it aggravated me, click on pic to enlarge
so I investigated further
Problem is that the clips supplied are not the same angle as the original and there was a piece of plastic interfering
Here is the clip
If you look at the plastic grille notice the area were I cut it
I also bent the mounts and corner of the grille to get that flush look
Also remember to use the Original Clips
Cheers
Where is scottx ?
This is a truly labor of love on this Old Girl ..lol. From entry level to S Klass with new grille.:thumbsup:
W201, W212, W221, & W222 Moderator
All you need to do now, is swap in a manual trans and you've got yourself a sexy, but bulletproof and fun to drive car!
Discussion Starter #14 (Edited)
Sound Complete :)
Final Specs
4" 2way Kicker 30RMS Speakers Upfront
6x9 3 Way speakers in the rear
Custom Rear Shelf for 6x9's
4 Guage wiring kit
Starsound 4 Channel Amp 4x75RMS @ 4 Ohm
Fire Audio Mono Block Amp 1x 1500RMS @ 1 Ohm (Class D)
Custom Backboard to mount the amps
12" Targa DVC 2 Ohm Street Series
40L Box made from MDF
JVC KD-R621 MP3, usb, iPod Ready, 3 RCA Connectors
Bluetooth Adapter
Steering Remote
Inspector checking the Box lol
Jeeze, that's scary! Glad you made it out alright!
1 - 20 of 21 Posts
