1 - 19 of 19 Posts
Moderator
190E, SLK350
Brakes that is!
I replaced the rear driver side bake caliper then I bled it. For good measure, I bled the whole system. Started from the rear passenger caliper, rear driver side, front passenger side and finally the driver side. In all steps I used a power bleeder and closed the bleeder screw when no bubbles where seen.
The final result is horrible! The brake pedal feels mushy and I get that uncertain feeling that the car will not stop where I need it.
I tried the whole process again but this time with the engine ON. Same result! I even tried it one more time while asking my wife to pump the brake pedal with the engine is on. No luck!
I used a Motive power bleeder and I set the pressure to 15psi. I have gone through two large bottles of brake fluid so far. Technically this is a flush by now.
Any ideas? What is it I am doing wrong?
1987 420SEL
The last time that happened to me, I had to dis-assemble a master-cylinder and then I just ended up rebuilding it and assembling it with varying methods of sucking brake fluid through it.
This was on a 1955 Jeep though; the basic of the basics.
I have absolutely no idea how to do this on a W126, sorry, nor would I even have the courage to try messing with the master. Hopefully someone else who's had this happen can chime in.
Depends on the day!
MB calls for 30psi, 15 won't do it.
pump the pedal up before using the power bleeder. I like to run a full L plus through my system when I do a flush.
Jonathan
'86 E300 Diesel '82 300 SD '87 560 SEL
You made me look...
Are the brakes good enough to go drive it and make the ABS kick-in? Apply the brakes so the ABS runs a few times. It might take care of the problem.
Moderator
190E, SLK350
I tried a sudden stop to engage the ABS, that didn't make a difference.
Depends on the day!
yup.
engaging the ABS won't do it. 30psi...
Jonathan
Moderator
190E, SLK350
Discussion Starter #11
30psi didn't make a difference!
I am at a loss here, I saw no bubbles, dirt or discolored fluid come out, just plain clean fluid. I used up FIVE large bottles of brake fluid today alone.
I tried this with engine off and engine on, pump the brakes, press the brakes; no difference whatever the method!
Depends on the day!
That being the case, sounds like your master is shot.
Jonathan
Moderator
190E, SLK350
Discussion Starter #13
How did that happen? It was fine right before I installed the brake caliper. Did I kill it?
Depends on the day!
You may have had one push to the floor, and if the bore of the master was a bit eaten up that could do the seal in...EASY to do.
W/ a pressure bleeder you won't have to bench bleed your master btw:)
Jonathan
Moderator
190E, SLK350
Discussion Starter #15
I was aware of that push to the floor of death so I really tried to avoid it. Maybe my wife did it, I need someone to blame...
I guess off to the junkyard I go unless this part is readily available and reasonable.
Depends on the day!
expect to pay around 200-ish for new.
The wife always works..now worries your secret is safe w/ us!
Jono
Moderator
190E, SLK350
Discussion Starter #17
damit, I tried to do one more thing this afternoon after I got a PM that I should only turn the key in the ON position then bleed but the main hose for the Motive Power Bleeder sprung a leak through a pin hole and shot my wife right in the face. It was kind of a naughty thought but then again that shit is corrosive, so no playing around.
Now I am stuck and will have to wait and see if I can get that hose separate because that whole power bleeder ain't cheap considering that I only use it once a year.
Depends on the day!
where did it spring a leak? If it's close to the base I'd just cut it back some.. I don't think the hose is anything spectacular..home despot etc should likely have something that would do..
And yes, brake fluid any where close to one's face it a BAD thing..it does a # on one's eye's right quick!!!!!
Jonathan
1 - 19 of 19 Posts
