2008 E350W4 multifunction displays no data. Lit up bright white but blank also no odometer or gear indicator
tach, fuel and temperature indicators operating normally. I do not see a fuse listed dedicated to this function?
Photo attached
Automotive lighting Gauge Automotive design Steering part Motor vehicle
2007 E280 CDI 4Matic
Questions for you! Does your climate control, wipers and headlights work? I can see that the rev counter needle is working, but does your speed counter needle work?
If these work, than it might be a problem with just the instrument cluster lcd which can be replaced. (
Anyway i also recommend you to check for codes before trying anything.
