Mercedes 1998 SL600 R129 Mercedes 2001 E430 W210 1997 Renntech E60 Dodge 2006 Power Wagon
How hard is it to change the turn signal switch on a 97' E420. Also does anyone have the part number?
'01-E320 & 02-ST2
The hardest part will be removing the steering wheel; I think if you look in the DIYs for the retightening process (it might be in the 140 forum?) you'll see all that is required.
You're in the US, so there is no reason for you not to sign up for the EPC: EPC-net Online They want a credit card to verify residency, but it's free, they don't charge you anything. Then you can get all the part numbers you want, whenever you want. :thumbsup:
'01-E320 & 02-ST2
Looks like autohausaz.com has the switch for under $90, too.
01 e320 4matic wagon
Yeah if its like the procedure for my 01 then its pretty much an easy DIY. Hardest part for me was removing the right side airbag screw everything else was cake.
