HERE ARE THE SPCIFICS ON THE A/B FLEXIBLE SERVICES:<br> YOUR A SERVICE SHOULD INCLUDE:<br> -CHANGE VEHICLES ENIGINE OIL AND FILTER<br> -REPLACE THE DUST FILTER IN ALL SLK,CLK,C-CLASS AND E-CLASS MODLES<br> -ENSURE THE WARNING AND INDICATOR LAMPS,HORN,WINDSHIELD/HEADLAMP WIPER AND WASHER SYSTEMS, AND SEAT BELTS ARE FUNCTIONING CORRECTLY<br> -INSPECT ITRES AND CHECK TIRE PRESSURE (INCLUDING SPARE)<br> -INSPECT BRAKE PAD THICKNESS AND DISC CONDITION<br> -CHECK AND CORRECT ALL FLUID LEVELS<br> -RESET YOU VEHICLES FSS COUNTER<br> YOUR B SERVICE INCLUDES ALL THE ABOVE AND THE FOLLING:<br> -REPLACE WINDSHIELD WIPER INSERTS<br> -INSPECT AND ROTATE TIRES<br> -LUBRICATE AND INSPECT THROTTLE LINKAGE<br> -ENSURE PARKING BRAKE,STEERING PLAY, HEADLAMPS AND EXT. LAMPS,WARNING AND INDICATOR LAMPS, HORN WINDSHIELD/HEADLAMP WIPER AND WASHER SYSTEMS, SEAT BELTS,ARE FUNCTIONING CORRECTLY.<br> -INSPECT FRONT AXLE BALL JOINTS AND POLY-V-BELT<br> THE REASON FOR THE LOANER CARS ARE CHEAP IS DUE TO INSURANCE/LIABILITY FOR LOANING OUT ACTUAL MERCEDES-BENZ.<br> NO DEALERSHIP SHOULD OFFER YOU ANY DIFFERENT KIND OF WARRANTY, IT IS FOUR YEARS OR 50K WHICHEVER IS FIRST, UNLESS YOU PURCHASE A STARMARK VEHICLE,(USED CAR)<br> ALIGNMENTS ARE FOR ONE YEAR OR 12K WHICHEVER IS FIRST.<br> NOT EVERYTHING IS INCLUDED IN THE SERVICES, BRAKE PADS, TIRES, WIPER INSERTS (AFTER THE FIRST YEAR OR 12K) ALL WEAR AND TEAR ITMES ARE NOT COVERED UNDER ANY WARRANTY. TIRES WILL ALWAYS BE UNDER THE ORIGINAL MANUFACTURERS WARRANTY, NOT MERCEDES BENZ!<br> CANADIAN VEHICLES HAVE THE SAME WARRANTY AS U.S. VEHICLES, HOWEVER, 2000 AND NEWER VEHICLES DO NOT HAVE THE FLEXIBLE SERVICES PAID FOR!-ANY OTHER QUESTIONS, LET ME KNOW, I WORK FOR A DEALER!<br>
