41 - 45 of 45 Posts
1981 Case 406
Thanks again for your answer, There are some on Ebay right now, The aluminum MRAP supposedly weighs 78lbs so it says. That is w/o the tire of course, There is a similar wheel listed but it is made of steel and it is listed at 116lbs per wheel w/o rubber. The tire itself is listed at 222lbs and it is new. Yeah, I agree the Unimog Nato rims are lighter.
1986 U1300L Expedition Camper
Hi uni406, I have verified the mass of various wheel / tire combinations on a pallet scale. I think this might help answer some of your questions. Changing from the stock setup to the Hutchinson MRAP wheels & 395 XZL combo adds just over 50 kg per corner. I suggest to remove the runflats in each tire. They dramatically increase the overall mass of the wheel / tire system with little to no benefit for general civilian use.
OEM 11X20 steel wheel: 33.66 kg
Michelin 365/80R20 XZL: 70 kg
Total: 103.66 kg
Hutchinson10X20 Al wheel: 34.5 kg
Hutchinson bead lock: 13 kg
Aluminum adapter plate: 5.5 kg
Michelin 395/85R20 XZL+: 100 kg
10 bolt studs & nuts: 4.5 kg
Total: 157.5 kg
The Hutchinson part numbers are:
Outer component: W0-1137 B
Inner Component: WI-1137 F
Beadlock: N/A (sorry, I don't have this part number)
Seal: N/A (sorry, I don't have this part number)
Hope that helps.
1981 Case 406
Thank you sir!
That is very, very helpful information. Hope others will see this as well.
Thanks again!
2001 W163 ML270CDI / 2006 W164 ML500 / 1986 U1300L Unimog
It could be worse. My Trilex wheels are 80kg BEFORE putting rubber on them. I dream of alum MRAPS for my U1300L hahaha.
UNIMOG, Gelaendewagen
These guys have great prices on MRAP Hutchinson wheels. What you’ll pay through the nose for are good adaptors. Couch’s are a really nice option.
41 - 45 of 45 Posts
