Hi, i just ordered a new c-sport with the comand system. Is there any way to connect an mp3 player. I just want navigation and an mp3 player. While asking, it seems that the comand only has 4x20Watts. Is it also possible to add some more power. Many thanks in advance
Discussion Starter · #2 ·
there is no conection build in, but you can add one by yourself. look at megacomm.de for more detailed informations and plans to add an connector for discman , walkman or mp3 player.....<br>
You can add an after market amplifier with more power and you also can replace the factory speakers with better ones.<br> <br> On the MP3 front..........If you are willing to sacrifice bandwidth you can go with a FM modulation or FM broadcaster and send in the MP3 files in to the system.<br>
You should find a micro-jack in the glove box. You can plug in an MP3 player and select it's source from NAVI. Get one with a remote, and you can navigate using that.
Discussion Starter · #5 ·
Thanks a lot.<br> I will my kill my car-seller in a few days because he told me it was impossible to use an auxilary source. The ùicro-jack is there and works fine
