1 - 9 of 9 Posts
2016 GLE 400 4Matic
After owning my CLK 500, C209 for about 13-14 years. I finally trade it in for a GLE 400 4matic fully loaded. So far I’m impress with the 3.0L V6 bi-turbo. I’m still getting use to the gadgets and other options.
2607468
2016 GLE 400 4Matic
I just notice the driver side camera under the side mirror is not working I’m getting a black solid square on the screen all the other camera are working. I made an appointment with the dealer this Friday to get it checked out.
2016 GLE 400 4Matic
Update
MB updated a new version of the software. Did not fix the 360 side camera. They order a new camera. Should be arriving by Tuesday.
2016 GLE 400 4Matic
I ran my iCarsoft MB II scanner for the hell of it and found (4) hidden stored code.
B21059a - No data found.
U040100 - Implausible data were received from the ECM.
C40100 - No data found.
U012187 - Communication with ESP has a malfunction.
Do you think all (4) codes were related to a dead or drain battery? I know the GLE was sitting at the dealer lot for a few months at least before I purchased It (this what the manager told me).
2005 CLK320
I would just clear them and see if any come back, it's most likely nothing.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Agreed, make a note of them and clear them. After a few drive cycles scan it again and see if they come back. A flat or even low battery will throw a number of codes.
2016 GLE 400 4Matic
I did not clear it because I took the GLE to the dealer this morning and I sent my service provider of the snap shots of the DTC. I have them look into it while there installing the 360 replacement camera and I told them to make sure all the firmware is up to date.
2016 GLE 400 4Matic
Update
MB got the camera in and they replace the main battery due to low voltage. The updated firmware they won’t update it unless something wrong with it.
1 - 9 of 9 Posts
