1987 300E, 1955 Plymouth Belvedere, 2005 Silverado 4x4
I'm sure this has been covered before but the answer seems to be hiding somewhere in the archives. Anyway, Im finally getting around to mounting a console box from a later model 124 into my '87 and before I start drilling the two screw holes into the console, does anyone know if there are any wires or likewise damagable items likely to be hidden under the console? The car is factory stock except for an aftermarket cell phone and that cabling was run along the door sills.
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
Ya get out of the gutter there.
Now to the question the screws go in at an angle and there shouldnt be anything in the way. If youre worried take about 6 more screws out lift the back of the console up and look under it youll see. The shift wood area is a little bit different size so I am not sure if the cubby area is the right size but if if is your good to go.
99-C43, 05-G55K, 71-280SL, 94-E320 CAB
If you don't want to drill, then run two parallel strips of VHB tape on the bottom...
