1 - 16 of 16 Posts
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
My todo list got a little shorter. theres no more danger to the manifold..... :)
Need to finish:
Charging System
Engine wiring
Power steering System
Down pipe
Cooling system plumbing
IAC system
Ignition system
today i did:
fuel system
MAS system
Exhaust manifold and the intake manifold
installed water pump and egr system
and a few misc things
started at 6 ended at 930 it took longer because i kept loosing my tools and when i cleaned up i put away a few baggys of screws that i finally found..
at 6pm:
clean intake chamber:
MAS bolted:
Exhaust manifold in:
Fuel injection:
Water Pump:
2000 :W220 - 1986 W201: 16v Nam,16v Euro- 2002:SL500 Silver Arrow.2002:Avalanche-
Good pics & job jippi , manifold and vacuum isn't it real challenging work ? engine wiring is better cauz you can't plug-in wrong places Hey looks very clean...can wait to turn key and CIS adjustment..by the way how cold inside your "bed-room" today...:D:thumbsup:
IR MODERATOR
dunno probably 50 ish inside the garage, it was 70 in the house and about 35ish outside. i had a space heater but didnt feel much of a difference.
IR MODERATOR
Down pipe bolted:
New power steering filter ( yes it does exist)
Pump bolted
cant forget the cap:
Back on the ground:
IR MODERATOR
1984 190D 2.2
Looks good! Maybe you can have it back on the road by the weekend
IR MODERATOR
spent 2 hours on resealing the subaru throttle and idle ystem because the car ran like crap since i got it it runs alot better. but made a point to do a litle work on the 190, spent an hour or so wiring it installiing the fan belt and fillin the psp.
also working on a new look for my winter wheels. i had a spare 15 hole.
1984 190D 2.2
How did you refinish the wheels?
Is that wurth spray paint?
IR MODERATOR
duplicolor wheel paint. they need to be cleared but i had time on my hands and extra paint from some volvo wheels i refinished a while back. i had extra wheels and they were a little dull so. the reason i did it was because the silver 15 holes were too plain and i wanted the blacked out look even in the winter. is it worth it? depends on you i think it is because they are plain cheap stock 15 holes so it wasnt worth getting them powder coated so as a cheap alternative painting is the way to go.
1984 190D 2.2
I was planning on doing this awhile back since mine have the clearcoat peeling. Already bought some duplicolor paint too, but just didn't think it would look good. Seeing how good yours turned out just put this back on my list.
IR MODERATOR
Discussion Starter #12
:D:D:D i scuffed the old finish up and got most of the brake dust off and also used adhesion promoter too.
IR MODERATOR
Discussion Starter #14
shes alive..... muhahahaha
1984 190D 2.2
IR MODERATOR
Discussion Starter #16
1 - 16 of 16 Posts
