1995 E320 1974 280C
Does anyone know the difference between Motor mount part# 124 240 22 17 and 124 240 19 17.
Some sites say one is the correct fit for my 95 E320 Sedan...some say the other is correct.
Thanks in advance, Peter
1995 E320 1974 280C
Anyone know the difference between the two? part# 124 240 22 17 and 124 240 19 17
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
22 17 is made by Febi while 19 17 is made by Lemforder. Both are respectable, but Lemforder is better abeit a tad more expensive.
The issue is that these are not just rubber mounts -- they are hydraulic and so that brings in the importance of quality. Don't get cheap Chinese made hydraulic mounts or expect early failures and leaks.
99 SLK230 Kompressor, 5 Speed Manual
Just so you know, the manual and automatic models take different motor mounts. I don't have details of part numbers, but I thought it might help to know this while you're puzzling it all out.
Hope this helps.
