1999 S500; W140.051; 2003 E320; W211.065; 1973 220; W115.010
Car: 2003 W211 E320 sedan with 'Avante Garde' option.
MOST ring was open due to retrofit of android headunit installed with wired architecture that completely bypassed the MOST system. There was 'open ring' condition after this install as I didn't have enough MOST 'loopbacks' to try to close the loop. This is a car that I got for my daughter and I was 'out of time' for repairs so I had to leave the 'open MOST ring' condition for later.
Some months later my daughter came to visit and I was able to get back into furthering my research project on the MOST system.
I wanted to get rid of MOST & AGW completely as it wasn't doing anything useful anymore.
I was able to get SOS system completely disconnected to get rid of the annoying periodic "SOS" errors.
I was able to re-code thru Star to remove all options in MOST ring. Unfortunately there are not coding options for AGW & Command unit. I set all options in MOST as [Vacant]. Then I put a MOST loopback at the POF connections on the AGW. In effect, this made a 'closed' MOST ring with the AGW as the only device.
Surprisingly, this will scan free of errors for the AGW system, but there are still some errors under System Diagnosis but this does not cause any MIL errors in instrument cluster.
I still had and "SRS" MIL I thought was due to the passenger seat weight sensor mat, but scans seem to indicate that it may have something to do with disconnecting the SOS unit.
There is a Telecommunnications Module (N112) mounted in the trunk that is next to the SOS related box.
N112 module is not on the MOST ring, but I think that the chassis number is causing the system to generate an error because SOS is not present. I think that the Telematics system does some check and generates the "SRS" malfunction because it doesn't find the SOS connected on the MOST ring or via the electrical connector which is also unplugged to the SOS unit.
Error details:
Control unit: AB - Airbag - F (Fail)-
MB number: 002-820-6426 HW version: 47.2001 SW version: 24.2002 Diagnosis version: 9/0 Pin: 101
Error Code: 9030
Text: "The coding for the digital crash output to control module N112 (Telecommunications control module) is faulty".
Status: Current and stored
Any ideas on the nature/reason for the error cited above or how to code the car to resolve the issue with N112 without "SOS".
Error details:
Error Code: 9030
