1 - 1 of 1 Posts
Hello All:
Someone posted a procedure to do a coolant change with the Mity-Vac on the ML sometime back. They said it could be done in 15 mins. The post indicated you removed the upper radiator hose after draining the expansion tank. It didn't say exactly where the old coolant was drained from. Does anyone know if the coolant is drained from the radiator or the engine block. I don't see how it could be from the block without removing the thermostat,also is the new coolant put in the expansion tank? Just getting my gearhead thing going again. Thanks in advance for any info or DIY anyone might know of.
1 - 1 of 1 Posts
