500SE AMG, E350 4matic, GL 450
I looked http://www.thebenzbin.com/ for a monovalve, the search came up with ACC mono valve ($147) and a repair kit ($44). For any of you who have had the no heat problem, can I get by with the repair kit or do I need the whole $147 piece. If anyone knows of a place with cheaper prices, please let me know. I will also be ordering O2 sensors for my w163 and probably injectors for the 300SEL.
Time for another one of my dumb questions....is it one injector per cylinder?
A bunch o of 'em - see signautre
Highly unlikely that you need the whole valve assembly - you can check it in 7 minutes. Pull the insert and look at the rubber diaphragm. If its torn pop in a new one. You can find them cheaper on the net (don't remember where I got mine).
As to injectors - I'm no mechanic and may get corrected, but I've not heard of a production engine with more than one injector per cylinder.
00 S500,99 4wgn,87TD
yes- 1 per cyl. as 4 the valve, the original, 000 835 06 44 by Bosch has a list of 59.00, cost 40 to 45.00. If you want to go a little cheaper, like around 20.00, order an insert for a 1988 535i BMW. same insert but an aftermarket is available for the BMW, not the Benz.... kev
Depends on the day!
check you pm's:)
jonathan
