Mercedes
i tried using the search feature but it was being a real bitch and got pretty annoying...anyways, i pulled a couple of relays out of the box and you can tell there was a minor condensation build up under the relays (dryed up now) ...could my fuel pump relay have blown causing my fuel pump to be unregulated then burn itself out? i just had a brand new fuel pump installed and my car doesnt start again, i replaced the fuel pump relay and fuse and still nothing...before the car went out there was not much power going after pressing the gad pedal...any ideas or thought? i was thinking of just ordering another bosh fuel pump and making sure to moisture got into the relay...OHHH did i mention that the car didnt start the morning after it rained all night?
2004 C230 Kompressor Sport Coupe
So you are getting no fuel pressure up at the engine? Moisture can cause all sorts of weird things, can you get the car inside and dry it out?
