Somewhere in another thread Esde wrote:
http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2005167/showCustom-0/p-2005167/N-111+10201+600001611/c-10101
These are pretty high quality, 6 fuse (just like 406/416) blocks, that take modern ATO fuses. Unlike a lot of the aftermarket fuse blocks, these have SIX INDIVIDUAL CIRCUITS, not six branches off a common bus. They are almost exactly the same width as the OEM fuse blocks and will fit side-by-side in the original location. All one needs to do is disconnect the wires, solder or crimp spade lugs and attach to the new blocks.
This is a great way to ditch the Lucas/Bosch clip-in fuses and the "issues" that go along with them. Plus, if the time ever come to go back to stock, it's pretty easy to "unconvert".
I have bought two of these fuse blocks:Here in the US Mcmaster-Carr sells 12 and 24 volt solenoid valves for pressurized gas. I bought 2 for about $25 each, and will install them with lighted switches as indicators. I'm waiting to do it till I get around to moving the fuse panel, replacing it with a waterproof marine unit that accepts blade style fuses. I can't stand those pesky pellet style fuses! I'll probably move the panel to the firewall on the passenger side as there's lots of room there. Hope this helps, Seth
