At idle and slow speeds the AC in my 2000 ml55 was going warm. I discovered the fan was not turning. I bit the bullet as I need the truck running and bought a new fan. Everything is working again. In the replaement I discovered that the plug was mangled making it impossible to plug in the new fan. I had to graft a replacement plug on the leads to make the new fan work. I would like to test my old fan now to see if it still works when receiving the right signals. According to the information I can find the speed control is PWM from 10% to 90% duty cycle, but I havent found the voltage or frequency of the input signal to duplicate it with a pulse generator. Is it 12V or are the control signals stepped down? Does anyone have a reference of experience with these details?
Mike in ABQ
Mike in ABQ
