Hello, I have a leak on the Pass side where the manifold connect to the CAT headpipe. Right where the two bolts clamp the two pieces together.
I the old days, there would be a donut there, I don't seam to find anything searching or on the parts listings online. They were thoughtful enough to use a nut and bolt, so I think I can just cut the old one off and put new bolts back in, I just don't want to drop it, unless I have the parts to fix it...
I have to look again, but I don't think that will work, it's not a flat surface like the head is, it's a flared pipe connection, either there's nothing and it's just an interference fit, or some kind of donut I believe...
The gasket that was posted is for the exhaust manifold to the cylinder head and not for the exhaust pipe.
There is no gasket for the mating of the exhaust manifold to the exhaust pipe. The convex portion of the exhaust manifold (green) fits exactly into a concave cavity in the exhaust pipe, which is the seal.
Thanks as always for the confirmation, that's what I assumed after looking at that manifold picture, kind of hard to tell with it bolted up in the car.
Funny effing thing, I start it up today, no freaking noise!!! I put my hand by it a couple of weeks ago when I changed the battery, and I could feel the leak while it was running...
I'm sure the bolts will snap, but I guess it just needs to be tightened....
I saw that on ebay also, but there's nothing left of the bolts, so they're going to snap inside the nuts for sure. The bolts look like M8 8mmx1.25mm pitch, 58mm long.
So I finally got around to it, check engine light on, O2 sensor code.
Replaced both bolts and nuts, bottom bolt frozen in the flange, had to drill it out. Hardest part was removing the inner liner!!! The very few, inexpensive, easy to do jobs on this car. Usually a PIA and expensive!!!
Yay!!! This is what mine looks like I was gonna go from the header back to be safe anyone replaced theirs with high flow universal ones? I was thinking those with Borla muffler and delete secondary’s with AMG tip
Could it be that the Rear cats (or fronts) are getting clogged & causing backpressure and that's causing your joint to leak exhaust ?
My pair of rear Cats got clogged so I just did a delete and put straight pipes in their place.
(they have no o2 sensors so can't tell by MIL light)
ML runs much better now. Exhaust shop owner alerted me to the possibility when we had him weld up a crack on the PS side front Cat - He said looks like excess heat caused this - I bet the rears are clogged....
Ok yeah Duh I guess if youre in New York that's a common issue. Rust that breaks bolts is to this Southern guy, a bit of an anomoly. We have other issues besides Rust !
Cheers - David in Texas
Related Threads
Mercedes-Benz Forum
7.6M posts
693.6K members
Since 1999
