2000 ml430, vw mk6
it was working fine and now the ac dials have no power and ac does not turn on could it be a fuse haven't checked it yet maybe relay
2000 ml430, vw mk6
Now the whole cluster lights up. You can hear the compressor turning on but no air I already checked the blower fuses could it be a bad blower
Sent from my iPhone using AG Free
02 ML320 06 ML500
Turn the A/C on and turn the blower dial to the max setting. Then check both contacts at fuse #43. If 12v is present swap relay K21 with a similar relay in the fuse box and see if the blower works. If not.............
Remove the panel under the passenger side, and access the blower motor. Using a DVOM, test the White wire for 12v and then the Pink wire for ground.
