Hi guys
I am new to the forum and would like some help with an issue I am having with the mentioned vehicle.
I am getting an intermittent misfire when I come to a sudden stop and sometimes when at a stand still in traffic.
The misfire is only on the engine bank on your right if you stand in front the car.
We have changed coils, exhausts (in case of blocked cats), oxygen sensors, cleaned injectors, and changed fuel filter.
During the misfire the fuel pressure does not drop so we decided not to change the fuel pump.
A test was also carried out to be sure that the voltage to the coils was correct as recommended by a Benz tech.
Any help with this problem would be greatly appreciated.
Thanks Guys
Zotye Auto 1.5T T600 2016
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
W164 M-Class - Benzworld.org - Mercedes-Benz Discussion Forum
