I have an ml350 that had a headlight issue.
It only has 1 foglight on when it is on auto.
However, any other mode that uses the foglight will turn both on normally.
Any easy fix to this?
When you press the fog lamp switch it sends a signal to the AAM to turn the fogs on. It is then the responsibility of the AAM to turn them on.
If while in the AUTO mode one does not turn on, then the fault must lie with the combination switch on the steering column.
