2001 ML320
ML320 throwing P0156 P0141 and P0442 [Edit: and P0161]
Today my 99 ML320 threw:
P0156
P0141
P0442
The truck has 155K and was running with no codes but a bit rough at idle before they showed up. What would be the best way to troubleshoot the problem? I do not have access to freeze frame data but could make a trip to autozone to get it if necessary. Any help is much appreciated. Thanks.
02 ML320 06 ML500
Code P0442 shows that there is a small leak in the Evaporative System. Remove the gas cap and look carefully at the large O-ring. If it is dried and has small cracks in it, it must be replaced. If the cap is OK then you will have to bring the truck to an independent mechanic who has a smoke machine.
Code P0141 is for a faulty heater circuit on the right side after cat. O2 sensor (arrow). That must be replaced.
The other code P0156 is for a faulty 02 sensor on the left side after cat. (bracket). Leave that one alone for now until after you replaced the right side O2 sensor.
2001 ML320
Update
The truck threw a P0161 today as well. have not ordered the right side sensor yet. Do I need to replace the left as well?
