1 - 8 of 8 Posts
ML320 2003 VW CC 2010
The wife called and said the car started and immediately shut off last night and left her at work. I went over to take a look and saw the start error show up. I did a little research on the forum, read briefly about the DAS and possible issue with the chip in the key so I took my spare key over and it acted the same. I pulled the battery and put in a new one and again it started and shut off and showed start error. Instead of lighting the car on fire I called AAA and they towed to my garage. As soon as we pushed the vehicle inside I tried again and the damn thing started fine. I tested it again this morning and no issue. I would like some advice on where to start troubleshooting. Im guessing Ill most likely have to go to the stealer based off what ive read.
Outstanding Contributor
2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
Here's a troubleshooting guide published by MB. In your particular case, it sounds like you need a new transponder ring, that comes assembled with its control box, which is the part that goes bad. You have an intermittent code-reading fault.
I wouldn't be driving it anywhere until it's fixed.
I fixed the links. Hope you can see the images now. I can.
1 - 8 of 8 Posts
