2000 ML320 W163 - 164.531
Can anyone tell me difference between 36-00024-AN Fuel Pump and a 36-00024-ON Fuel Pump? Looking online, the AN pump is much cheaper than the ON and I am not sure which one to purchase.
I have a problem with the engine shutting off after running for a short while. I have replaced the fuel filter and pulled the fuel pump to inspect it. Everything looks to be in working order but I could not find a part number on the fuel pump. Also, I have found that if I shift the car into neutral and crank the engine, it fires right up. Could there be a switch on the transmission or shifter that is going bad?
Any suggestions would be much appreciated. Thanks
2004 CLK 240 Coupe
I don't know the answer to your specific question....but you might be interested in this SI from the WIS about fuel pump replacement on W163.
That is, if your engine No/serial No is included in the SI references. :thumbsup:
Of course, the modification might already have been done.
1999 ML320 Elegance, BMW R1150RT, SAAB 9-3
re; Any suggestions would be much appreciated.
i suggest getting a fuel pressure gauge to see if your issues are indeed fuel delivery related.
Through all of the troubleshooting that I have done, the fuel system has maintained pressure at the fuel rail. I read the SI on W163 and if I am reading it correctly, I do not have a retrofitted pump. The part number that I get off of the pump is A163 470 10 94. I will have to gain access to the filter again to be able to get the number off of it.
Is there some sort of a fuel shutoff switch integrated in the shifter or tranmission. The car will run for hours in the driveway.
2004 CLK 240 Coupe
None that I can find on the drawings...
btw - if you have to use the larger fuel filter (with pressure regulator) the fuel lines will need to be modified accordingly. I have a WIS drawing that covers this work - if you require it.
Discussion Starter · #6 ·
Thanks. I might need the info but I will need to check out the filter to see what I have first.
Dallas, Texas
If fuel pump maintains rail pressure why are you looking for for replacement? Fuel delivery is only 1/3 of equation. What about spark, air and injection pulse.
There is contradiction between two posts describing your problem.
