1 - 12 of 12 Posts
· Super Moderator
02 ML500, 00 ML320, 05 E500 4M Wagon, 99 ML430
Thanks for the effort on making the video Peter.
Just a couple of notes that people can decide for themselves and their climate.
MB has gone to the recommendation of using the fleece fiber filters.
Also the oil should meet MB Spec 229.5. All we use is the Mobil 1 0w40 or the Total Quartz 9000 5w40. There are lots of 229.5 spec oils. The ones I listed are easily obtained in my area.
99 White ML320, 13 Audi S5,84 300ZX Turbo, 03 Audi A4, 03 Audi TT, 65 Ford Galaxie Conv
Noodles, can you provide brands for the filters or is it noted on the packaging. Never looked to see what the filter material is, just buy high end brand.
2002 ML500; 2007 BMW 335XI
1998 ML320
On most of the web stores I looked at they will say fleece or paper. And not much difference in the price.
Am I the only one here looking at this and thinking "nice video" right up to the point where I noticed the OP was Hawaii all nice and warm?:D
1999 ML430 and 2003 ML55
Enjoyed the video. Very well done! This is the singularly most important DIY task for an ML owner...also the easiest ! I prefer the suction method but the results are identical.
I would add that it is very important to check the level again , AFTER the engine has been run at idle for a few minutes. Allow the oil to fully drain back into the sump and then check with the dipstick. Often you will need to add a small amount to bring it to the proper level.
Also, please note that the filter comes with five new O-rings.Two are identical. Only the four are required to be replaced , as the video describes.
I highly recommend the outfit oilchangekits.com for one-stop shopping convenience. See below:
Mercedes Synthetic Filter Oil Change Kit (9 Quarts) w/ Total Energy 9000 at OilChangeKits.com
99 s320,and 83 300sd
I'am wanting a w163,can you if you wanted to drain oil from the bottom? Also I read where cotton fleece filters had the cotton hulls in the cotton,that could get loose in your oil.
Current 2017 GLE350, 2007 S550, 2002 S430, 1998 ML320 Deceased 74 240D, 92 400E, 97 E420, 13 GLK350
Actually, the weevils proved to be more problematic in cotton fleet oil filters - my Blackstone oil analysis kept coming back exceeding the MB spec for insect parts, but always within spec for hulls.
When I bought a polyester blend llama and switched wool fleece filters this problem was solved. :D
Black 1999 ML320
To answer your first question, yes the oil pan has a drain plug. You can drain it from the bottom.
1 - 12 of 12 Posts
