1999 ML320
So, I just found out that the catalytic converters are clogged on my ML and the shop says that they will only replace the whole unit front to back (no cut and switch). Their quote for the job: $1,700. They want about $1500 for just the parts. I was looking online though, and found a couple of aftermarket companies that sell direct OE fit cats and am wondering if they are of decent quality.
These are pretty cheap:
Mercedes ML320 catalytic converter 98 99 00 01 02 RIGHT - eBay (item 190470435351 end time Mar-19-11 09:53:21 PDT)
Also, these seem to be decent:
Mercedes Benz ML320 Eastern Catalytic Converter - 1998-2001 Mercedes Benz ML320 - Eastern EAST40461
I guess I'm curious how you distinguish a good catalytic converter from a bad one or whether one would be the same as any other. I live in Missouri, and we don't have emissions testing here, so I am not concerned about that.
2005 E320 CDI, 2016 E250
I personally chose the Magnaflow Hi Flow cats that needed welded in. $75 for each of the two I put in and cut the other two. Added an aftermarket exhaust and for around $600 or so you can replace the entire system.
500SE AMG, E350 4matic, GL 450
Are both sides clogged? Are you getting misfire codes on both sides? Anyway, here are some instructions on changing the driver side cat. I did not change the passenger side both it looked much easier than the passenger side. I have owned 2 w163's and have had to change cats on both. Both times I bought them from germanstar.
The M-Class Outpost - The M-Class Enthusiasts' Site
