1 - 20 of 20 Posts
2000 ML320
Guys I need some help. My trusty ML320 (2000 model) seems to have an issue.
2 weeks ago my car sounded very strange on startup. So I switched off the ignition and removed key to open the hood. Unfortunately it sounded like my engine continued running even after the ignition was switched off and key removed. While watching all this, Smoke appeared and my starter burned out. Seems like the starter stay engaged. Replaced the starter and yesterday the same thing happened.
On starting the car, some strange noise appeared, when switching off the starter again kept running, I pulled relays in order to get it off, but unfortunately no luck and starter again went up in smoke.
What could cause this issue?
Sent from my Redmi 3 using Tapatalk
2000 ML55 sold? 2013 ML500,? 2017 C43 AMG,1929 Victory 6 roadster, 1927 Dodge 4 sedan, 1929 Dodge
You might have to look under the fuses and relays for rodent damage. Sounds like a couple of wires have been chewed through and shorting out.
· R.I.P. Gone but not forgotten
2006 ML500 2002 ML320
Any chance it is the ignition control module? That is the part my mechanic wants to replace?
There is no ignition control module, unless he means the Eng. Control Module.
If he does, then don't let him replace it. There has never been a reported replacement of the ECM for this type of issue.
Dallas, Texas
Yes I did, but starter continued until it burned out
Disconnecting battery negative is only hope in case like that. If starter continued after removing F1k8 ECM is out of the loop. You need to find another mechanic.
BTW ignition switch is out of the loop as well. It only sends request for starter operation. Starting function is controlled by ECM.
You will have to check all the wires under the fuse module. Remove both covers to the fuse box, then remove the three screws and pull the fuse/relay module out of the fuse box.
Check the following wires at their respective connectors:
MR/E-#8 wire WHITE
MR/E-#13 wire Blue/Yellow
P/A-#2 wire Grey
M/C-#12 wire Violet
2000 ML320
Discussion Starter · #18 ·
No missing or damaged wiring
Mechanic believes the ignition switch is the problem. New starter installed but new ignition switch on order. For now he installed a switch to cut power from the starter to prevent the starter from burning.
Almost a week driving like this (part is arriving on Friday). And this morning a nice surprise when my car wouldn't start at all. Dash lights lit up but no crank - hopefully only a loose wire but will check that out.
Dallas, Texas
For all you girls out there here is small challenge!!!!
1. Put key in ignition and turn it to position 1 Take mental note (phone picture)
2. Turn is to position 2. Ditto.
3. Turn in into position 3 and hold it. Do not let go!!! Describe your experience?
2000 ML320
Discussion Starter · #20 ·
Just an update. Found the K8 relay burned.
Installed ignition switch. Unfortunately would not start normally, not sure where wiring was intercepted for the switch, but something is preventing it to start. Took power directly from battery and connected to switch until car can go back to original mechanic this coming Friday to reconnect the wiring correctly so that car can start without the switch.
I will continue to start with switch for now. BTW the ignition switch is in shortage in South Africa at the moment with only one MB agent having stock so expect a wait if you need one outside Gauteng.
1 - 20 of 20 Posts
