1 - 20 of 20 Posts
I am new to BENZ. I bought a second hand ML320 40000KM. May I know what should do on the first service? Should i change oid filter etc...
I brought Benz Club to check, but the reports shows the body condition only.
please help!!!
German Karts
thats a nice looking truck. I'm in the process of buying an '02 ML320 myself (actually it's MY2001 but sold here as MY2002 for some reason). This one is still 2 color though, but only has 30,000km on it. Regularly maintained at the dealer so they have service record for it.
Answering your question, you should check that with nearest MB dealer around you. I've done general check up on the car (visual check, mechanical check, electrical check, and test drive), and there are several things that needs changing.. air filter, front brake pads + sensor, and a/c pollen filter. The battery is weak but still usable.
So, I think you should check that with your MB dealer to see whats need to be changed/repaired.
SLK55,CayenneS,XKR
ZeroLimit - 4/17/2006 10:51 AM
Thats seems its a goodbuy , Very Low Mileage for a 2001 Model[:)]
1999 ML 430
paulxu - 4/17/2006 7:59 PM
I don't think so, it's priced at 228,000, I'd guess it's in Hong Kong, because this truck would be worth between USD 28,000 to USD30,000 in Taiwan but not at $7000.
if you read that front license plate it says autohongkong.com so you were right [8D]
ZeroLimit - 4/17/2006 11:56 PM
Does carfax works for car sold outside of north america?
Won't cover the Asian part of service, but will show the car's history in US.
The car was build in US.
Even if it won't show much -it is still worth checking it. 20-years old diesel MB with one owner in US will show zero records on carfax, but everybody will check it anyway.
ML320
Hi Newbie
Im in Hong Kong too and have same year/model as you. You bought that in the underground mall next to Grand Hyatt if im not mistaken?
You can check the VIN on the Russian MB website - it proved very accurate on mine.
Watch out for MB HK - they will charge you an arm and a leg for everything. All garages in HK can fix Mercedes well because they are more common than anything else!!
HK cars tend to be low mileage, low owner with excellent appearance. You have to watch the brakes, gearbox as many hills though mine is fine. ALso minor damage as crowded with cars so bumps/scrapes normal. They cover them well at the repair shops :)
Did you pay HKD228,000? I paid HKD210,000 after the sticker showed same. Also got them to wire-up ipod..
Cheers
Alex
Discussion Starter · #19 ·
Ml320
The Pig said:
Hi Newbie
Cheers
Alex
Hi Alex
Where you take your car to server? do you have suggestion? my email [email protected]
1 - 20 of 20 Posts
