1998 ML320
Hey guys.
I have a ML320 model 1998. I've been experiencing problems with the windshield wipers. The rear windshield wiper didn't work when I bought the car but I wasn't making a big deal out of it, I never use it anyway.
The front windshield wipers stopped working in the top speed settings but all other speed settings worked. Now however the front windshield wipers don't work at all. I can however sometimes get them started by turning them on and then go and wiggle the wipers about and then they start wiping. I can't turn them off because then they stop again and I need to use the same method again to get them started. This is getting a bit annoying.
Any ideas what could be the problem? Is the windshield motor dying on me? Has anyone had a similar problem?
02 ML320 06 ML500
Are you saying that you have to move the wiper arms to get it wok? If so then it is your wiper motor.
You will have to be very careful about the part number. If you are getting it from the dealer, then there shouldn't be any problem. But if you are buying it used or on-line, then your vin # is important.
The first part # in the illustration is for an ML up to 089349.
The second part # is for a ML as of 089350.
1998 ML320
Yes, I need to move the wiper arms with my hands after I turn them on to get them to start wiping.
Thanks for the info.
2004 w211 E320 base
i have the motor for the rear wiper if you need it, it came of a 1998 ml320 shoot me a pm with your zipcode to estimate ;)
