ml270
hot starting ml270
hi all,
Ihave had numerous problems with starting when engine is warm or hot . MB HAVE HAD THE CAR ON 4 OCCASIONS !!this has resulted in new immobalizer unit and transponder, 2 new injectors fuel line and valves plus more recently new air mass flow that was for another reason . Today car started from cold and then when hot wouldnt . The recovery man sprayed easy start spray in inlet, and it started . he stated it could be cps sensor or another injector ? Could anyone share their knowledge with me please . Many thanks.once engine cools it starts again!
javascript:emoticon('flame')
flame
_________________
all help considered
View user's profile
2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
Tony,
Please scan the truck for OBDII codes during the 'no start when hot' episodes.
If you come up with the code P0335, change your Crankshaft Position Sensor and you're good to go.
02 ML320 06 ML500
When starting fluid starts a vehicle it is a fuel delivery problem. Check fuel pressure with a gauge when the event occurs; fuel filter or fuel pump.
ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
many thanks car booked into merc next
week will let you all know thanks
The cps is a strong favourite for causing this kind of problem and it doesnt always throw up a fault code.
