2002 ML320
HI all,
For the second time I filled, I noticed a strong gas smell, for 2 days... or at least till gas lowers inside....I see or can find No visible leak..but there is a smuge as if gas was present near the main fill hose.... I rocked the ML and the smell is defenetly coming from the hose are in the rear tire.
Any help would help.. Thanks guys!!!!
Leaky ML.... :mad:
· Outstanding Contributor
2006 ML500 2002 ML320
It could very well be that a nipple is leaking as azinn said, but before you go and replace the fuel pump, remove the left rear tire and the plastic wheel liner and the left rear seat and investigate. It could be any one of the plastic hoses pictured in the diagram, any of which can be purchased separately.
