The Dueler H/L Alenza with UNI-T and UNI-T AQII is Bridgestone's light truck and SUV Highway All-Season tire that was developed for the drivers of premium, luxury sport utility vehicles. The Dueler H/L Alenza is designed to provide elegance with an edge, as well as year-round traction, even in light snow.
All Dueler H/L Alenza sizes feature Bridgestone's UNI-T technology to take tire behavior to a higher level by increasing comfort and control. In order to further enhance wet traction, select sizes have Bridgestone's UNI-T AQII technology which features dual layer tread compounds to resist the normal tread rubber hardening that results from the heat encountered during thousands of miles of use. As the tire wears, the special underlying high-grip rubber is exposed, helping offset the effects of wear on wet traction. The result is that UNI-T AQ II helps handle wet road conditions even as the tire wears.
On the outside, the symmetric tread pattern of the Dueler H/L Alenza has been ride and noise tuned to enhance comfort. Large shoulder blocks and a continuous center rib boost responsiveness and highway stability, while wide circumferential grooves, lateral notches and sipes help increase stormy weather traction. On the inside, twin steel belts (reinforced with spirally wound nylon for H-speed rated sizes) provide support under the tread area, while polyester cords stabilize the sidewalls and enhance ride quality.
The Dueler H/L Alenza...Elegance with an Edge
