Mercedes ML 350
The check engine light just came on with the low fuel light blinking. Still 1/2 tank of fuel. Please help:confused:
02 ML320 06 ML500
Reading the codes that are stored for the Check Eng. Light will probably reveal code P0460 which is Fuel Too Low.
It's probably a partially clogged fuel filter which is making the electronics believe it is really low on fuel, or a faulty fuel pump float.
Have the codes read regardless, it could also be a misfire .
2014 ML550, 2012 E63, 2006 SL500R
This could also be a bad seal on the gas tank cap.
Next tank of gas, make sure you get the cap and good twist and hear the clicks.
Zotye Auto 1.5T T600 2016
+1 the flashing light is to tell you the cap is not on correctly.
